Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10/100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
- C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 1.5 m - blue
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 1.5 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
