C2G 1.5m Cat6 550 MHz Snagless Crossover Cable - Black
Quicklinx: 6BSDWS00 Mfr#: 83541
Length: 1.5m
Colour: Black
£9.20 ex VAT
£11.04 inc VAT
Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
  • Enhanced connectivity
    The Cat6 Booted Unshielded (UTP) Crossover Patch Cable is designed for superior network performance, offering a tested frequency of up to 550 MHz. This ensures reliable, high-speed data transfer for a range of networking applications.
  • Durable design
    Featuring a robust PVC jacket material and gold-plated connectors, this cable is built to withstand rigorous use while ensuring optimal signal integrity. The 24 AWG American Wire Gauge size further enhances its durability and performance.
  • Universal compatibility
    With its T568B wiring scheme and RJ-45 connectors, this crossover cable is compatible with a wide range of devices, making it a versatile solution for connecting PCs across different network configurations.
C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 1.5 m - black
Crossover cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
1.5 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 1.5m
Colour: Black
Brand: C2G
