C2G 1.5m Cat5E UTP LSZH Network Patch Cable - Grey
Quicklinx: CMGZWS00 Mfr#: 82449
For fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels with a LSZH outer jacket. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-code your network installation. Each cable is individually labelled with the length for ease of use.
Connector 1: (1) RJ-45 Male.
Connector 2: (1) RJ-45 Male.
  • Enhanced connectivity
    Featuring gold-plated RJ-45 connectors, this patch cable ensures a secure and corrosion-resistant connection, enhancing signal clarity and strength.
  • Durable design
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket, the cable minimizes environmental hazards and ensures durability, making it suitable for both commercial and residential installations.
  • Reliable performance
    Equipped with features like minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this CAT 5e cable delivers reliable, high-speed data transmission with minimal interference.
C2G patch cable - 1.5 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Booted, snagless, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL), latching clip
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Jacket Material
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
56 g
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2
