C2G 1.5m Cat5e Assembled Cable WHT
Quicklinx: 6BLBWS00 Mfr#: 83122
Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Assembled Patch Cables from C2G distribute data, voice and video over today's advanced fast Ethernet and gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-performance capabilities. Tested up to 350 MHz, this cable is designed to meet the demands of both residential and commercial networking needs. The use of 24 AWG wire within a durable PVC jacket alongside a T568B wiring scheme maximizes the efficiency and stability of your network.
  • Enhanced durability
    Featuring gold-plated connectors, this patch cable not only promises superior conductivity but also boasts increased corrosion resistance. The meticulous construction extends the lifespan of the cable, ensuring that your network setup remains robust and reliable over time.
  • Universal compatibility
    Designed to support a wide range of devices, the Cat5e Non-Booted Unshielded (UTP) Network Patch Cable comes with male RJ-45 connectors on both ends, making it highly versatile. It's compatible with PCs and a multitude of network devices, facilitating easy integration into existing setups without the need for additional adapters.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
1.5 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
