C2G 1.5m Cat5E 350 MHz Snagless Patch Cable - Green
Quicklinx: 6BMDWS00 Mfr#: 83202
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and improved signal integrity for your network. Its gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, enhancing the overall performance of your network infrastructure.
  • Durable design
    Featuring a robust PVC jacket material, this network patch cable is built to withstand the rigors of daily use in various environments. The boot cover adds extra strain relief that protects the cable's most vulnerable point from damage, ensuring a longer lifespan and maintaining optimal network performance.
  • High-speed performance
    Tested to support frequencies up to 350 MHz, this patch cable is capable of delivering high-speed data transmission. It's perfect for supporting the bandwidth requirements of modern networks, including fast Internet, streaming, and gaming applications, without compromising on speed or quality.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
