For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 American Wire Gauge (AWG) copper wires, ensuring reliable connectivity and improved signal integrity for your network. Its gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, enhancing the overall performance of your network infrastructure. -
Durable design
Featuring a robust PVC jacket material, this network patch cable is built to withstand the rigors of daily use in various environments. The boot cover adds extra strain relief that protects the cable's most vulnerable point from damage, ensuring a longer lifespan and maintaining optimal network performance. -
High-speed performance
Tested to support frequencies up to 350 MHz, this patch cable is capable of delivering high-speed data transmission. It's perfect for supporting the bandwidth requirements of modern networks, including fast Internet, streaming, and gaming applications, without compromising on speed or quality.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - green
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Green
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 1.5 m
- Green
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
