C2G 1.5m Cat5E 350 MHz Snagless Patch Cable - Brown
Quicklinx: 6BW5WS00 Mfr#: 83674
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires, ensuring reliable connectivity and high-speed data transfer rates of up to 350 MHz. Its gold-plated RJ-45 connectors provide optimal signal clarity and shielding against interference, making it a suitable choice for both home and office networking needs.
  • Durable design
    Featuring a robust PVC jacket material, this network patch cable is built to withstand the rigors of daily use. The boot cover for the RJ-45 connectors not only adds an extra layer of protection but also prevents the cable from snagging during installation and cable management. This design choice ensures a longer lifespan and maintains the integrity of your network.
  • Universal compatibility
    With its T568B wiring scheme and compliance with RoHS standards, the Cat5e Booted Unshielded (UTP) Network Patch Cable is compatible with a wide range of devices and networks. Whether you're connecting PCs, routers, or switches, this cable supports seamless integration into virtually any network infrastructure.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 1.5 m - brown
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Brown
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
Brown
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
