C2G 1.5m Cat5E 350 MHz Crossover Patch Cable - Blue
Quicklinx: 6BNKWS00 Mfr#: 83299
This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
  • Enhanced connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable connects two devices directly for data sharing without the need for a network switch or hub, offering a straightforward solution for device-to-device communication.
  • High-quality performance
    With a tested frequency of up to 350 MHz, this crossover cable supports high-speed data transmission for your networking needs. The American Wire Gauge (AWG) of 24 and gold-plated connectors minimize resistance and interference, ensuring a reliable connection.
  • Durable design
    Constructed with PVC jacket material and featuring a T568B wiring scheme, this cable is built for durability and optimal signal integrity. The unshielded twisted pair (UTP) technology reduces crosstalk, making it suitable for various networking environments.
C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 1.5 m - blue
Crossover cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
1.5 m
Blue
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
