C2G 0.9m (3ft) USB C to DisplayPort Adapter Cable 4K - White
Quicklinx: DWK1WS00 Mfr#: 80563
Length: 90cm
£30.15 ex VAT
£36.18 inc VAT
Experience 4K ULTRA HD displays with this USB-C to DisplayPort Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet, smartphone or other device, and the DisplayPort input of a projector or display – making it an ideal solution for the office, work space applications or classrooms. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed an audio/video signal to a DisplayPort monitor to achieve high quality, 4K (ULTRA HD) video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient solution that eliminates the need for a separate adapter or additional cabling, offering a straightforward installation.
  • Colour
    White
  • Warranty
    3 Years
  • Connector 1
    USB-C Male
  • Connector 2
    DisplayPort Male
C2G 0.9m (3ft) USB C to DisplayPort Adapter Cable White - 4K Audio / Video Adapter - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
DisplayPort (male connector)
Length
90 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Graphics Engine
Chrontel CH7213A
Max Resolution
3840 x 2160 at 30 Hz
Plug and Play, Directive 2011/65/EU
Length
90 cm
49 g
Enclosure Colour
White
Limited warranty - 3 years
50 °C
25 - 70%
Length: 90cm
Brand: C2G
