C2G 0.9m (3ft) USB C Cable M/M - USB 3.1 (3A) - Black
Quicklinx: DWR3WS00 Mfr#: 88830
Length: 90cm
The USB-C to C 3.1 Male to Male Cable is the perfect solution for connecting two standard USB Type C enabled devices or accessories up to 3ft apart for fast charging and high-speed data transfer. Whether you're desk-based or on-the-go, this one-cable solution ensures that your USB-C equipped laptop, smartphone or tablet is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music or data at speeds up to 5 Gbps. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • High-speed connectivity
    Experience rapid data transfer with a 5 Gbps data rate, ensuring efficient sync and charge capabilities for your devices.
  • Robust design
    Featuring nickel-plated connectors and compliant with USB 3.1 Gen 1 standards, this cable is designed for durability and reliable performance.
  • Universal compatibility
    Equipped with USB-C connectors on both ends, this cable supports a wide range of devices, making it a versatile addition to your tech collection.
C2G 0.9m (3ft) USB C Cable - USB 3.1 (3A) - M/M USB Type C Cable - Black - USB-C cable - 24 pin USB-C to 24 pin USB-C - 90 cm
USB-C cable
Sync and charge, 5 Gbps data rate
Length
90 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB 3.1 Gen 1
3-year warranty
USB-C cable
Rated Current
3 A
Plated Connector
Nickel
Length
90 cm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1 Gen 1, UL 20276, RoHS 2 (2011/65/EU)
3-year warranty
Length: 90cm
Brand: C2G
