The USB-C to C 2.0 Male to Male Cable is the perfect solution for connecting two standard USB Type C enabled devices or accessories up to 3ft apart for fast charging and high-speed data transfer. Whether you’re desk-based or on-the-road, this one-cable solution ensures that your USB-C equipped Chromebook, laptop, smartphone or tablet is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music or data at speeds up to 480 Mbps. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
- C2G 0.9m (3ft) USB C Cable - USB 2.0 (3A) - M/M USB Type C Cable - Black - USB-C cable - 24 pin USB-C to 24 pin USB-C - 90 cm
- USB-C cable
- Sync and charge
- Length
- 90 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- 3-year warranty
- USB-C cable
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Sync and charge
- Length
- 90 cm
- Black
- Connector
- USB / USB 2.0, RoHS 2 (2011/65/EU)
- 3-year warranty
