C2G 0.5m Velocity[TM] DB9 Female to 3.5mm Male Adapter Cable
Quicklinx: DWQQWS00 Mfr#: 87188
Why run cables for RS-232 control of your audio/video system, when you can use this easy adapter? The Velocity RS-232 adapter leverages your DB9 or 3.5 mm stereo audio cable to run 3-conductor RS-232 control signals between your control unit and your video display. Fully molded DB9 and 3.5 mm connectors provide excellent strain relief. This adapter is ideal for use with computers, projectors, and any control unit/display requiring 3-conductor RS-232 serial control.
  • Versatile connectivity
    The C2G Velocity DB9 Female to 3.5mm Male Adapter Cable offers a seamless connection between devices, featuring a mini-phone stereo 3.5 mm male connector on one end and a 9-pin D-Sub (DB-9) female connector on the other. This design ensures compatibility with a wide range of audio and serial devices, making it a must-have for PC users seeking reliable connections.
  • Durable design
    Engineered with strain relief, this serial cable is built to withstand the rigors of daily use. The durable construction ensures a stable connection between devices, minimizing the risk of damage and loss of signal integrity over time. It's an ideal solution for users who require a dependable link between their PC and serial or audio equipment.
C2G Velocity DB9 Female to 3.5mm Male Adapter Cable - serial cable - mini-phone stereo 3.5 mm to DB-9 - 50 cm
Serial cable
Molded, thumbscrews, strain relief
Length
50 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Serial cable
Length
50 cm
Connector
