Why run cables for RS-232 control of your audio/video system, when you can use this easy adapter? The Velocity RS-232 adapter leverages your DB9 or 3.5 mm stereo audio cable to run 3-conductor RS-232 control signals between your control unit and your video display. Fully molded DB9 and 3.5 mm connectors provide excellent strain relief. This adapter is ideal for use with computers, projectors, and any control unit/display requiring 3-conductor RS-232 serial control.
Effortless connectivity
The DB9 Male to 3.5mm Male Adapter Cable from C2G Velocity ensures a seamless connection between devices. With a strain relief feature, it provides durability and a secure connection, making it ideal for various PC applications. -
Versatile compatibility
Designed to meet the needs of diverse PC environments, this serial cable features a mini-phone stereo 3.5 mm and a 9-pin D-Sub (DB-9) connector, offering broad compatibility across multiple devices.
- C2G Velocity DB9 Male to 3.5mm Male Adapter Cable - serial cable - mini-phone stereo 3.5 mm to DB-9 - 50 cm
- Serial cable
- Molded, thumbscrews, strain relief
- Length
- 50 cm
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- Black
- Limited lifetime warranty
- Serial cable
- Length
- 50 cm
- Black
- Connector
