Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
High-quality connectivity
The 0.5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD features a gold-plated connector that ensures a reliable, high-quality connection between devices. This construction minimizes signal loss and interference, delivering a clear, vibrant video and audio experience. -
Durable design
Constructed with a PVC jacket and shielded with aluminum foil and braid, this HDMI cable is designed for durability and long-lasting performance. The robust build protects against external interference, maintaining the integrity of the digital signal. -
Versatile compatibility
Supporting HDMI with Ethernet, this cable is compatible with a wide range of devices, from gaming consoles to streaming devices and more. It facilitates network connectivity and allows for the sharing of an Internet connection between multiple devices without the need for separate Ethernet cables.
- C2G 0.5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 50 cm
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Cable Type
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminium foil with braid
- Impedance
- 100 Ohm
- Length
- 50 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- UL
- Limited warranty - lifetime
