C2G 0.5m Select High Speed HDMI with Ethernet
Quicklinx: 915FWS00 Mfr#: 80550
Type: HDMI
Length: 50cm
£4.19 ex VAT
£5.02 inc VAT
Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • High-quality connectivity
    The 0.5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD features a gold-plated connector that ensures a reliable, high-quality connection between devices. This construction minimizes signal loss and interference, delivering a clear, vibrant video and audio experience.
  • Durable design
    Constructed with a PVC jacket and shielded with aluminum foil and braid, this HDMI cable is designed for durability and long-lasting performance. The robust build protects against external interference, maintaining the integrity of the digital signal.
  • Versatile compatibility
    Supporting HDMI with Ethernet, this cable is compatible with a wide range of devices, from gaming consoles to streaming devices and more. It facilitates network connectivity and allows for the sharing of an Internet connection between multiple devices without the need for separate Ethernet cables.
C2G 0.5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 50 cm
Cable
Shielded
American Wire Gauge (AWG)
28
Length
50 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Impedance
100 Ohm
Length
50 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
UL
Limited warranty - lifetime
Type: HDMI
Length: 50cm
Brand: C2G
