RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated Break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
RapidRun multi-format represents the most significant upgrade to the RapidRun cabling solution to date. With enhanced engineering that includes individually shielded pairs and an isolated ground for audio lines, this solution meets the rigorous demand for applications in which multiple audio/video devices are run over a single cable.
Versatile connectivity
The C2G RapidRun VGA (HD15) + 3.5mm Flying Lead offers versatile connectivity options with its VGA and audio interface, enabling seamless connection to a wide range of multimedia devices. -
High-quality construction
Crafted with high-quality materials, this video/audio cable ensures reliable signal transmission and durability for extended use, making it an ideal choice for both professional and home environments.
- C2G RapidRun VGA (HD15) + 3.5mm Flying Lead - video / audio cable - VGA / audio - 50 cm
- Cable
- Video / audio cable - VGA / audio
- Length
- 50 cm
- Black
- Connectors
- HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- MUVI connector - male
- Limited lifetime warranty
- Cable Type
- Interface Supported
- VGA / audio
- Length
- 50 cm
- Black
- Connectors
- 15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
- Limited warranty - lifetime
