The C2G "Value Series" stereo right angle audio cable is specifically designed to provide a brilliant audio experience. It connects a PC sound card, portable CD player or any mini-stereo audio device to a multimedia speaker. This cable features two copper conductors and a drain wire. The conductors and drain wire are wrapped with an aluminum Mylar shield which prevents unwanted EMI/RFI interference. Fully molded nickel-plated connectors provide excellent strain relief for durable use.
- C2G Value Series audio cable - 50 cm
- Cable
- Audio cable
- Technology
- Shielded
- Length
- 50 cm
- Black
- Connector
- Stereo mini jack - male
- Connector (Second End)
- 90° connector, right-angled connector
- Limited lifetime warranty
- Cable Type
- Audio cable 90° connector, right-angled connector
- Technology
- Shielded
- Shielding Material
- Aluminium mylar
- Length
- 50 cm
- Plated Connector
- Nickel
- Moulded
- Black
- Connector
- Mini-phone stereo 3.5 mm - male
- RoHS
- Limited warranty - lifetime
