One end of this power cord will work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector; the other end features a 2-prong Schuko European plug. The female connector plugs directly into device, while the male connector plugs into the standard European outlet. This premium, heavy-duty, 16 AWG cord features a fully moulded design for maximum durability and long life.
Versatile compatibility
Designed to power PCs, this universal power cord is the ideal fit for any workspace, ensuring your equipment stays powered with reliability. -
Durable design
Featuring a robust 16 AWG cable, this power cord is built to withstand the demands of daily use, providing a dependable power connection to your devices.
- C2G Universal Power Cord - power cable - power CEE 7/7 to power IEC 60320 C13 - 50 cm
- Power cable
- Molded
- Length
- 50 cm
- Localisation
- Europe
- Connector
- Power CEE 7/7 - male
- Connector (Second End)
- Power IEC 60320 C13
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 16
- Molded
- Length
- 50 cm
- Black
- Localisation
- Europe
- Connector
