C2G 0.5m 16 AWG Universal Power Cord (IEC320C13 to CEE7/7)
Quicklinx: 6C50WS00 Mfr#: 88541
Length: 50cm
£4.22 ex VAT
£5.06 inc VAT
One end of this power cord will work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector; the other end features a 2-prong Schuko European plug. The female connector plugs directly into device, while the male connector plugs into the standard European outlet. This premium, heavy-duty, 16 AWG cord features a fully moulded design for maximum durability and long life.
  • Versatile compatibility
    Designed to power PCs, this universal power cord is the ideal fit for any workspace, ensuring your equipment stays powered with reliability.
  • Durable design
    Featuring a robust 16 AWG cable, this power cord is built to withstand the demands of daily use, providing a dependable power connection to your devices.
C2G Universal Power Cord - power cable - power CEE 7/7 to power IEC 60320 C13 - 50 cm
Power cable
Molded
Length
50 cm
Europe
Connector
Power CEE 7/7 - male
Connector (Second End)
Power IEC 60320 C13
Power cable
American Wire Gauge (AWG)
16
Molded
Length
50 cm
Europe
Connector
Power IEC 60320 C13
Length: 50cm
Brand: C2G
