C2G 0.3m Cat6 Booted Unshielded (UTP) Network Patch Cable – Grey
Quicklinx: 9N25WS00 Mfr#: 83364
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • Enhanced connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality 24 AWG wire and a durable PVC jacket. The gold-plated RJ-45 connectors provide a secure link between devices, minimizing potential connectivity issues.
  • Optimized performance
    Designed to support the demands of CAT 6 performance, this patch cable features minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), ensuring high-speed data transmission and improved signal quality for your network.
  • Universal compatibility
    With T568B wiring scheme and compliance with RoHS and TIA/EIA-568-B.2-1 standards, this network patch cable is built to work seamlessly with PC systems, making it a versatile choice for a wide range of network applications.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 30 cm - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL)
Length
30 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Impedance
100 Ohm
Plated Connector
Gold
Length
30 cm
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2-1
