C2G 0.3m Cat6 Booted Unshielded (UTP) Network Patch Cable – Blue
Quicklinx: 9N26WS00 Mfr#: 83384
Length: 30cm
Colour: Blue
£2.94 ex VAT
£3.52 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • Enhanced connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with gold-plated connectors to ensure a high-quality connection and improved signal integrity for reliable network performance.
  • Durable design
    Featuring a PVC jacket material and an American Wire Gauge (AWG) of 24, this patch cable is built for durability and long-term use, minimizing the risk of cable damage and signal loss.
  • Optimized performance
    With minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable is engineered to enhance your network's speed and stability, supporting seamless data transmission.
  • Universal compatibility
    The cable's T568B wiring scheme and RJ-45 connectors make it compatible with a wide range of devices, ensuring a versatile solution for various networking requirements.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 30 cm - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL)
Length
30 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Pairs per Cable
4 pairs
Impedance
100 Ohm
Plated Connector
Gold
Length
30 cm
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B.2-1
Length: 30cm
Colour: Blue
Brand: C2G
