For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
                Enhanced connectivityThe Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with gold-plated connectors to ensure a high-quality connection and improved signal integrity for reliable network performance.
                Durable designFeaturing a PVC jacket material and an American Wire Gauge (AWG) of 24, this patch cable is built for durability and long-term use, minimizing the risk of cable damage and signal loss.
                Optimized performanceWith minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), this cable is engineered to enhance your network's speed and stability, supporting seamless data transmission.
                Universal compatibilityThe cable's T568B wiring scheme and RJ-45 connectors make it compatible with a wide range of devices, ensuring a versatile solution for various networking requirements.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 30 cm - blue
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL)
- Length
- 30 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Impedance
- 100 Ohm
- Plated Connector
- Gold
- Length
- 30 cm
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, TIA/EIA-568-B.2-1
