The 15cm 4-pin 3.5mm Male to Dual 3.5mm Female Adapter is the perfect solution for connecting a set of headphones and a microphone to a single 4-pin 3.5mm port on a laptop, tablet, mobile phone or other mobile device. Newer laptops, mobile phones and other mobile devices only offer a single 4-pin 3.5mm audio port capable of supporting both an audio input and an audio output. This adapter provides two separate 3.5mm ports that will support a mono microphone and a set of stereo headphones or a set of external speakers. The compact design of this adapter makes it easy to carry in a laptop bag or briefcase.
- C2G 4-pin 3.5mm Male to Dual 3.5mm Female Adapter - audio adaptor - 15 cm
- Cable
- Audio adaptor
- Length
- 15 cm
- Black
- Connector
- 2 x mono mini jack - female
- Connector (Second End)
- Mini-phone stereo 3.5 mm - male
- Limited lifetime warranty
- Cable Type
- Audio adaptor
- Length
- 15 cm
- Black
- Connector
- 2 x mini-phone mono 3.5 mm - female
- Limited warranty - lifetime
