C2G .5m VGA270™ HD15 UXGA M/F Monitor Extension Cable
Quicklinx: 63VBWS00 Mfr#: 81139
Type: VGA
Length: 50cm
12 in stock
£5.46 ex VAT
£6.55 inc VAT
Bring ultimate flexibility to your video applications with the patent-pending VGA270 UXGA monitor cables bY-C2G. The HD connectors on each end rotate from side-to-side in almost a complete circle, allowing you to position the cable to fit your installation. The connectors feature detents, or "click-stops", ensuring signal integrity is maintained. These premium UXGA cables are ideal for connecting video equipment such as projectors, video splitters, monitors and KVMs. With VGA270, the days of not having the right connector orientation on your cables are over!
C2G VGA270 UXGA Monitor Extension Cable - VGA extension cable - 50 cm
VGA extension cable
Shielded
Thumbscrews
Length
50 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA extension cable
Shielded
Shielding Material
Foil with braid
Thumbscrews
Length
50 cm
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
Type: VGA
Length: 50cm
Brand: C2G
Price Range Ex VAT: 0 - 50
