C2G .5m Pro Series HD15 UXGA M/M Monitor Cable
Quicklinx: 63PDWS00 Mfr#: 81000
Go the distance without ghosting and signal distortion. Constructed from premium grade composite coaxial and twisted pair shielded cables, this ultra-premium monitor cable ensures crisp, distortion-free video so you have maximum monitor positioning flexibility. Uses three internal coax lines for red, green and blue. Ferrited to protect against EMI/RFI interference, this double-shielded cable consists of 125% foil shielding and 90% tinned copper braid shielding. Use it for video projectors, video splitters, KVM switches within video presentations, classroom environments, POS devices, server rooms, etc. Will accommodate cable runs up to 100 feet without a booster (in most cases).
C2G Pro Series UXGA - VGA cable - 50 cm
VGA cable
Double shielded coaxial
Length
50 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
Foil with tinned copper braid
Length
50 cm
Connector
RoHS
