Brand
C2G .5m Pro-Audio XLR M To XLR F
Quicklinx: 67W9WS00 Mfr#: 80376
Pro-Audio cables from C2G are perfect for connecting line or mic level outputs from mixing consoles to recorders and amplifiers with balanced inputs. Highly flexible, 7mm PVC jacket reduces the risk of cables kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Chuck strain relief inside the XLR connector reduces the effects of age on the solder joints and contacts.
C2G Pro-Audio audio cable - 50 cm
Cable
Audio cable
Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG)
22
Length
50 cm
Connector
XLR3 - male
Connector (Second End)
XLR3 - female
Cable Type
Audio cable
22
Jacket Material
Flexible PVC
Shielding Material
Foil with copper braid
Length
50 cm
Plated Connector
Nickel
Connector
3 pin XLR - male
3 pin XLR - female
RoHS
