C2G .5m DB25 Male to DB9 Female Null Modem Cable
Quicklinx: 6836WS00 Mfr#: 81421
Null modem serial cables from C2G allow two DTE or DCE devices to communicate with no conflict in data transmission. The transmit and receive signals are crossed to ensure proper data transmission. These high quality-cables deliver data quickly and reliably over short distances. Cables in male-to-female configurations are typically used as serial printer cables, while female-to-female versions are typically connecting two PC serial ports.
C2G - null modem cable - DB-25 to DB-9 - 50 cm
Null modem cable
Shielded
Length
50 cm
Connector
25 pin D-Sub (DB-25) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Null modem cable
Shielded
Length
50 cm
Connector
RoHS
