For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-quality connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 supports efficient data transmission, making it an ideal choice for various networking requirements. -
Enhanced performance
Tested for frequencies up to 550 MHz, this patch cable meets the Category 6 (CAT 6) standards, facilitating high-speed data transfer and minimizing interference. The T568B wiring scheme further enhances performance, ensuring compatibility with a wide range of devices. -
Universal compatibility
Featuring RJ-45 male connectors on both ends, the cable is compatible with PCs and a broad array of networking equipment. Its compliance with RoHS standards underscores the commitment to environmental responsibility while delivering a high degree of interoperability.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - yellow
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 50 cm
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
