C2G .5m Cat6 550 MHz Snagless Patch Cable - White
Quicklinx: 6BRJWS00 Mfr#: 83485
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 supports efficient data transmission, making it an ideal choice for various networking needs.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this patch cable is engineered to enhance the performance of your network. The T568B wiring scheme and UTP technology facilitate a stable and secure connection, suitable for both home and office environments.
  • Universal compatibility
    This network patch cable boasts universal compatibility with PCs, ensuring a seamless connection to a wide range of devices. Its male RJ-45 connectors on both ends provide an easy and secure connection, making it a versatile choice for any setup.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
50 cm
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
