C2G .5m Cat6 550 MHz Snagless Patch Cable - Red
Quicklinx: 6BQTWS00 Mfr#: 83445
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transfer for server applications, cloud computing, and HD video streaming.
  • Durable design
    Constructed with a PVC jacket and 24 AWG wire, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide optimal signal clarity and resist corrosion, ensuring a secure and reliable connection between devices.
  • Universal compatibility
    Featuring a T568B wiring scheme and compatible with PC systems, this network patch cable offers versatile connectivity options. It's perfect for connecting computers, servers, printers, and other network devices within a LAN.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
50 cm
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
