C2G .5m Cat6 550 MHz Snagless Patch Cable - Purple
Quicklinx: 6BV1WS00 Mfr#: 83630
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 supports efficient data transmission, making it an ideal choice for various networking requirements.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this network patch cable is engineered to enhance the performance of your network. The T568B wiring scheme and UTP technology facilitate high-speed data transfer, suitable for PC compatibility and ensuring your network's efficiency and reliability.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - purple
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
50 cm
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
