C2G .5m Cat6 550 MHz Snagless Patch Cable - Brown
Quicklinx: 6BVDWS00 Mfr#: 83644
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a PVC jacket and gold-plated connectors to ensure durable and reliable connectivity for all networking needs. With the capability to support frequencies up to 550 MHz, this cable is perfect for high-speed data applications.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and adhering to the T568B wiring scheme, this patch cable offers seamless compatibility with PCs and a wide range of network equipment, making it a versatile choice for various setups.
  • Eco-friendly choice
    Compliant with RoHS standards, the Cat6 Booted Unshielded (UTP) Network Patch Cable not only delivers on performance but also upholds environmental responsibility, ensuring that your networking solutions contribute to a greener planet.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - brown
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Brown
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
50 cm
Brown
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
