C2G .5m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BPRWS00 Mfr#: 83385
Length: 50cm
Colour: Blue
£2.68 ex VAT
£3.21 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures your connections are reliable and fast, suitable for intensive online tasks, streaming, and gaming.
  • Durable design
    Constructed with a PVC jacket material and featuring gold-plated connectors, this patch cable is built for durability and long-term use. The robust design resists wear and tear, ensuring your network setup remains uninterrupted and efficient.
  • Universal compatibility
    With RJ-45 male connectors on both ends, this cable offers universal compatibility with a wide range of devices. Whether connecting to PCs, network switches, or routers, setup is straightforward and hassle-free.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
50 cm
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 50cm
Colour: Blue
Brand: C2G
