For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
High-quality connectivity
Featuring an American Wire Gauge (AWG) of 24 and a Category CAT 5e rating, this network patch cable ensures reliable connectivity with a tested frequency of up to 350 MHz. The PVC jacket material provides durability, making it suitable for various environments. -
Enhanced signal integrity
The gold-plated connectors on both ends of the cable not only offer a secure connection but also help in maintaining the integrity of the signal being transmitted. This is further supported by the T568B wiring scheme and UTP technology, which minimizes interference. -
Versatile compatibility
Designed to support a wide range of devices, this cable comes with male RJ-45 connectors on both ends, making it compatible with PCs and other devices requiring a network connection. Its universal design ensures easy integration into existing setups.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - yellow
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 50 cm
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 350 MHz
