Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Snagless Patch Cables from C2G distribute data, voice and video. These cables handle bandwidth intensive applications up to 350MHz and meet all Cat5E TIA/EIA standards. The molded, snag-free boot prevents unwanted cable snags during installation and provides extra strain-relief.
High-quality connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and gold-plated connectors, ensuring reliable, high-speed data transmission up to 350 MHz. This makes it a suitable solution for various networking needs, providing both durability and optimal signal integrity. -
Versatile compatibility
With its T568B wiring scheme and RJ-45 male connectors on both ends, this patch cable offers broad compatibility with PCs and other devices. Its unshielded twisted pair (UTP) technology minimizes noise and interference, enhancing connection quality for both home and office environments. -
Durable design
Encased in a PVC jacket, the cable is built to withstand rigorous use and maintain its integrity over time. The booted design not only adds an extra layer of protection but also makes handling and installation easier, preventing snags and ensuring a longer lifespan for your network setup.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - white
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 50 cm
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
