C2G .5m Cat5E 350 MHz Snagless Patch Cable - White
Quicklinx: 6BMXWS00 Mfr#: 83260
Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Snagless Patch Cables from C2G distribute data, voice and video. These cables handle bandwidth intensive applications up to 350MHz and meet all Cat5E TIA/EIA standards. The molded, snag-free boot prevents unwanted cable snags during installation and provides extra strain-relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and gold-plated connectors, ensuring reliable, high-speed data transmission up to 350 MHz. This makes it a suitable solution for various networking needs, providing both durability and optimal signal integrity.
  • Versatile compatibility
    With its T568B wiring scheme and RJ-45 male connectors on both ends, this patch cable offers broad compatibility with PCs and other devices. Its unshielded twisted pair (UTP) technology minimizes noise and interference, enhancing connection quality for both home and office environments.
  • Durable design
    Encased in a PVC jacket, the cable is built to withstand rigorous use and maintain its integrity over time. The booted design not only adds an extra layer of protection but also makes handling and installation easier, preventing snags and ensuring a longer lifespan for your network setup.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
