C2G .5m Cat5E 350 MHz Snagless Patch Cable - Red
Quicklinx: 6BMKWS00 Mfr#: 83220
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance for both home and office networks.
  • Durable design
    Designed with a robust PVC jacket and an American Wire Gauge (AWG) of 24, this network patch cable is built to withstand the rigors of daily use. Its durability ensures a dependable connection for your networking needs.
  • High-speed performance
    Capable of supporting tested frequencies up to 350 MHz, this CAT 5e cable facilitates efficient data transmission. It's ideal for applications requiring reliable network performance.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
