C2G .5m Cat5E 350 MHz Snagless Patch Cable - Green
Quicklinx: 6BMCWS00 Mfr#: 83200
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance for both home and office networks.
  • Durable design
    Designed with a robust PVC jacket and an American Wire Gauge (AWG) of 24, this patch cable is built to withstand the rigors of daily use. Its durability ensures a dependable network connection that users can rely on.
  • High-speed performance
    Supporting tested frequencies up to 350 MHz, this network patch cable is optimized for fast data transfer. It is suitable for supporting the bandwidth requirements of Internet connections, streaming services, and online gaming.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
