C2G .5m Cat5E 350 MHz Assembled Patch Cable - Green
Quicklinx: 6BKPWS00 Mfr#: 83060
Perfect for your home office or a large installation project, enhanced Cat5E 350MHz assembled patch cables from C2G distribute data, voice and video over today's advanced Fast Ethernet and Gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality American Wire Gauge (AWG) 24 wiring and gold-plated connectors. Designed for durability and optimal performance, the PVC jacket material protects the cable's integrity, even in various environmental conditions.
  • Enhanced performance
    With a tested frequency of up to 350 MHz, this patch cable is engineered to facilitate high-speed data transmission for PC compatibility. Its T568B wiring scheme and UTP technology minimize interference, providing a stable and efficient network environment.
  • Versatile connectivity options
    Featuring male RJ-45 connectors on both ends, the cable supports easy and secure connections between a wide range of devices. The inclusion of 4 pairs per cable and 8 wires per cable ensures comprehensive wiring configurations for diverse networking needs.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
50 cm
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
