C2G .45m USB to DB9 Serial Adapter Cable
Quicklinx: 63MCWS00 Mfr#: 81632
£13.40 ex VAT
£16.08 inc VAT
Connecting USB with the traditional RS-232 serial port, this adapter connects cellphones, PDAs, digital cameras, modems, or ISDN terminal adapters through your USB port. Has a data transfer rate of over 230 kbps. Since the adapter uses no IRQs, there are no IRQ conflicts, and it is ideal for when you need many serial devices attached to your PC. Frees your RS-232 port for other uses.
C2G USB to DB9 Serial Adapter Cable - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
160 g
RS-232
Data Transfer Rate
230 Kbps
Blue
Microsoft Windows 98SE/2000/ME/XP
1-year warranty
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
230 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 45.7 cm
RoHS
Blue
Additional Requirements
CD-ROM
System Requirements Details
Windows 98SE/2000/ME/XP - Pentium - 200 MHz
160 g
Limited warranty - 1 year
Brand: C2G
Stock Status: In stock
