Connecting USB with the traditional RS-232 serial port, this adapter connects cellphones, PDAs, digital cameras, modems, or ISDN terminal adapters through your USB port. Has a data transfer rate of over 230 kbps. Since the adapter uses no IRQs, there are no IRQ conflicts, and it is ideal for when you need many serial devices attached to your PC. Frees your RS-232 port for other uses.
- C2G USB to DB9 Serial Adapter Cable - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- 160 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 230 Kbps
- Blue
- System Requirements
- Microsoft Windows 98SE/2000/ME/XP
- 1-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 230 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated) - 45.7 cm
- RoHS
- Blue
- OS Required
- Additional Requirements
- CD-ROM
- System Requirements Details
- Windows 98SE/2000/ME/XP - Pentium - 200 MHz
- 160 g
- Limited warranty - 1 year
