The USB to Dual PS/2 Adapter from C2G is the ideal solution for those who want to use legacy PS/2 devices on USB systems. The USB to Dual PS/2 Adapter allows you to connect a PS/2 mouse and keyboard through the USB port on any computer. It's the ideal solution for connecting a full-size keyboard and mouse to the USB Port on your notebook.
- C2G Port Authority USB to Dual PS/2 Adapter - keyboard / mouse adapter - 31 cm
- Keyboard / mouse adapter
- Length
- 31 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 2 x 6 pin mini-DIN (PS/2 style) - female
- Black
- Limited lifetime warranty
- Length
- 31 cm
- Black
- Connector
- RoHS
