Buffalo's new AirStation™ Dual Band Gigabit router (WZR-600DHP2-EU) brings a new solution to Buffalo's family of wireless routers.
Upgrade your existing wireless connection with Buffalo's WZR-600DHP2-EU: a simple dual band solution with advanced features.
The WZR-600DHP2-EU provides simultaneous transfer speeds of up to 300MBps in both the 5GHz and 2.4GHz bandwidths; and managing two networks at the same time splits the workload for noticeably better performance. Perfect for streaming HD movies, music and emailing from multiple devices at the same time.
Gigabit Speed
With four gigabit LAN ports and one gigabit WAN the WZR-600DHP2-EU offer ultra-fast wired connections.
Easy, secure setup
The Buffalo AirStation™ One-Touch Secure System (AOSS™), Wi-Fi Protected Setup (WPS) and the new intuitive interface provide a quick and easy way to create a secure wireless connection to a host within minutes.
Easy file sharing
The WZR-600DHP2-EU also comes with USB 2.0 port, media server, device server, and BitTorrent™ for easy file sharing across connected devices.
Including Norton ConnectSafe
The AirStation™ Dual Band Gigabit router also offers Norton ConnectSafe™ that defends your network and family against unsafe or undesirable websites. It's a basic security that blocks access to problem sites and automatically protects your device against phishing and malware sites. Content from 30 categories is blocked while you keep the ability to always allow certain sites or make exceptions for single clients.
- BUFFALO AirStation WZR-600DHP2 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), MAC address filtering, VPN passthrough, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), BitTorrent Client, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
- Power
- AC 120/230 V (50/60 Hz)
- 2.8 cm x 18.5 cm x 20 cm
- 520 g
- System Requirements
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Line Properties
- Line Coding Format
- OFDM
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- 23 Watt
- Mounting Kit
- Included
- Software Included
- Norton ConnectSafe
- OS Required
- 2.8 cm
- 18.5 cm
- 20 cm
- 520 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
