The Buffalo WS-QL Windows Storage Server 2003 R2 Express Edition has been specially designed to provide an aggressively price performance entry NAS solution for small office environments, giving full integration with a Windows environment, along with the ease and familiar intuitive administration that Windows brings. Organizations of all sizes can create effective NAS solutions that can adapt to and solve the simplest or most complex storage needs. Buffalo Windows Storage Server 2003 R2 Express Edition, WS-QL, provides a fast and reliable platform for Network Attached Storage (NAS), built on the proven Windows Server 2003 R2 family code base with all of its superior security, stability and management advantages. The WS-QL adds new search capabilities, simplified set-up and storage management, and is specially tuned by Buffalo to provide optimal NAS performance.
- BUFFALO TeraStation WSS - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17 cm x 21.5 cm x 23 cm
- 8 kg ()
- Storage Controller
- RAID SATA 1.5Gb/s RAID 0, 1, 5
- Hard Drive
- 4 x 500 GB SATA 1.5Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2003 R2
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.3.9 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 17 cm
- 21.5 cm
- 23 cm
- 8 kg ()
- Built-in Devices
- Status LCD
Storage Controller
- RAID - internal
- Interface Type
- SATA 1.5Gb/s
- Supported Devices
- Hard drive, disk array (RAID)
- RAID Level
- RAID 0, RAID 1, RAID 5
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 500 GB
- Interface Type
- SATA 1.5Gb/s
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), HTTP, HTTPS
- Expansion Bays
- 4 (total) / 0 (free) x external
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A
- Power Device
- Internal power supply
- Voltage Required
- 75 Watt
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80%
