Buffalo TeraStation III 8TB NAS With Hot Swap
FULLY POPULATED NAS ENCLOSURE **8TB**
Quicklinx: 5JNGWS00 Mfr#: TS-X8.0TL/R5
Buffalo TeraStation III is a larger capacity NAS device with robust RAID 5 capability. The redundancy of four separate hard drives in RAID 5 or RAID 1 modes mean that even if a hard drive fails, your data is safe. With Hot Swap functionality, if a drive does fail, the TeraStation III automatically powers down the faulty drive, enabling you to safely remove and replace without losing any data, or down time. The replication function allows the connection of a second TeraStation via LAN port and replicates the data to improve reliability, fault tolerance or accessibility. The perfect solution for the home office or small to medium business that needs large, easy-to-deploy, easy-to-manage, redundant network attached storage.
BUFFALO TeraStation III - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
4 (installed) / 4 (max)
17 cm x 23 cm x 21.5 cm
8 kg ()
Europe
Storage Controller
RAID SATA 1.5Gb/s RAID 0, 1, 5, 10
Hard Drive
4 x 2 TB SATA 1.5Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
Microsoft Windows 2000, Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista, Microsoft Windows Server 2008
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
17 cm
23 cm
21.5 cm
8 kg ()
Built-in Devices
Status LCD, print server
Europe
Storage Controller
RAID - internal
Interface Type
SATA 1.5Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Hard Drive
HDD - hot-swap
4 x 2 TB
Interface Type
SATA 1.5Gb/s
128-bit AES
Network / Transport Protocol
TCP/IP, FTP, SMB
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Auto-sensing per device, hardware encryption, trunking, auto-uplink (auto MDI/MDI-X), print server, DFS support, FTP server, Buffalo Web Access, BitTorrent Client
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
4 (total) / 0 (free) x external
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A
Internal power supply
Software Included
NovaBACKUP Business Essentials (10 licences)
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
5JNG C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
Resources
The following resources are available for the Buffalo TeraStation III 8TB NAS With Hot Swap
