Buffalo Terastation III 2TB NAS With Hot Swap
WITH ROBUST RAID 5 CAPABILITY
Quicklinx: 5JNCWS00 Mfr#: TS-X2.0TL/R5
Buffalo TeraStation III is a larger capacity NAS device with robust RAID 5 capability. The redundancy of four separate hard drives in RAID 5 or RAID 1 modes mean that even if a hard drive fails, your data is safe. With Hot Swap functionality, if a drive does fail, the TeraStation III automatically powers down the faulty drive, enabling you to safely remove and replace without losing any data, or down time. The replication function allows the connection of a second TeraStation via LAN port and replicates the data to improve reliability, fault tolerance or accessibility. The perfect solution for the home office or small to medium business that needs large, easy-to-deploy, easy-to-manage, redundant network attached storage.
BUFFALO TeraStation III TS-X2.0TL/R5 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
17 cm x 23.1 cm x 21.6 cm
6.3 kg ()
Storage Controller
RAID SATA 3Gb/s RAID 0, 1, 5, 10, JBOD
Hard Drive
4 x 500 GB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
Microsoft Windows 98 Second Edition, Apple MacOS X 10.3.9, Microsoft Windows Vista / 2000 / XP
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
17 cm
23.1 cm
21.6 cm
6.3 kg ()
Built-in Devices
Status LCD
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
HDD
4 x 500 GB
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Spindle Speed
7200 rpm
Network / Transport Protocol
TCP/IP, FTP
Remote Management Protocol
HTTP
Network Services Compatibility
Microsoft Active Directory (AD), DFS, Server Message Block (SMB)
LDAP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Bays
4 (total) / 0 (free) x internal
2 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
Internal power supply
Software Included
Drivers & Utilities, Memeo AutoBackup
Limited warranty - 3 years
5 °C
35 °C
