Buffalo TeraStation III is a larger capacity NAS device with robust RAID 5 capability. The redundancy of four separate hard drives in RAID 5 or RAID 1 modes mean that even if a hard drive fails, your data is safe. With Hot Swap functionality, if a drive does fail, the TeraStation III automatically powers down the faulty drive, enabling you to safely remove and replace without losing any data, or down time. The replication function allows the connection of a second TeraStation via LAN port and replicates the data to improve reliability, fault tolerance or accessibility. The perfect solution for the home office or small to medium business that needs large, easy-to-deploy, easy-to-manage, redundant network attached storage.
- BUFFALO TeraStation III TS-X2.0TL/R5 - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- 17 cm x 23.1 cm x 21.6 cm
- 6.3 kg ()
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, 5, 10, JBOD
- Hard Drive
- 4 x 500 GB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 98 Second Edition, Apple MacOS X 10.3.9, Microsoft Windows Vista / 2000 / XP
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 17 cm
- 23.1 cm
- 21.6 cm
- 6.3 kg ()
- Built-in Devices
- Status LCD
Storage Controller
- RAID - internal
- Interface Type
- SATA 3Gb/s
- Supported Devices
- Hard drive
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 4 x 500 GB
- Interface Type
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Spindle Speed
- 7200 rpm
- Data Link Protocol
- TCP/IP, FTP
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Server Message Block (SMB)
- LDAP support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Expansion Bays
- 4 (total) / 0 (free) x internal
- 2 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Drivers & Utilities, Memeo AutoBackup
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
