Buffalo TeraStation 6400DN 8TB (4 x 2TB) 4 Bay NAS
Quicklinx: FG1QWS00 Mfr#: TS6400DN0804-EU
  • Atom
Marketing description is not available.
  • High transmission speed
    The 10GbE connectivity impresses with exceptional speed.
  • iSCSI Volume Backup
    iSCSI Volume Backup is a key feature of TS6000. If TS6000 is used to expand storage capacity of a server, the iSCSI volume backup allows data to be transferred directly from one TS6000 to another TS6000, without having to go through the server and thus reducing the server load significantly.
  • Replication with TeraStation
    By replication, a folder in two separate TeraStations is synchronized almost in real time. This only happens in one direction (not bi-directional) - from the source to the destination. This function can be set up in LAN and WAN. WAN setup includes remote connection via port forwarding and VPN setup.
BUFFALO TS6400DN Series TS6400DN0804 - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Total Storage Capacity
8 TB
4 (installed) / 4 (max)
17 cm x 23 cm x 21.5 cm
7.4 kg ()
Europe
1 x Intel Atom C3538 2.1 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10
Hard Drive
4 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
RAM
8 GB
AC 100 V (50/60 Hz)
3-year warranty
NAS server
Host Connectivity
8 TB
17 cm
23 cm
21.5 cm
7.4 kg ()
Built-in Devices
Status LCD
Europe
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB DDR4
ECC
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
HDD - hot-swap
4 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
Wake on LAN (WOL), full duplex mode, Buffalo Web Access, Apple Time Machine compatible, 2 fans, secure backup, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5"
1 x Ethernet 10Gb - RJ-45 , 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
1 x network cable - 2 m
RoHS, VCCI Class A, Green Purchasing Law
Internal power supply
AC 100 V (50/60 Hz)
85 Watt
Limited warranty - 3 years
10 - 85% (non-condensing)
