High transmission speed
The 10GbE connectivity impresses with exceptional speed. -
iSCSI Volume Backup
iSCSI Volume Backup is a key feature of TS6000. If TS6000 is used to expand storage capacity of a server, the iSCSI volume backup allows data to be transferred directly from one TS6000 to another TS6000, without having to go through the server and thus reducing the server load significantly. -
Replication with TeraStation
By replication, a folder in two separate TeraStations is synchronized almost in real time. This only happens in one direction (not bi-directional) - from the source to the destination. This function can be set up in LAN and WAN. WAN setup includes remote connection via port forwarding and VPN setup.
- BUFFALO TeraStation 6400DN TS6400DN3204 - NAS server - 32 TB
- NAS server
- Host Connectivity
- 10 Gigabit Ethernet
- Total Storage Capacity
- 32 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17 cm x 21.5 cm x 23 cm
- 7.4 kg ()
- Processor
- 1 x Intel Atom C3338 1.5 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, JBOD
- Hard Drive
- 4 x 8 TB SATA 6Gb/s - hot spare
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
- RAM
- 8 GB
- Power
- AC 100 V (50/60 Hz)
- 3-year warranty
- NAS server
- Host Connectivity
- 32 TB
- 17 cm
- 21.5 cm
- 23 cm
- 7.4 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 8 GB DDR4
- ECC
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 4 x 8 TB
- Interface Type
- SATA 6Gb/s
- Hot spare
- Data Link Protocol
- TCP/IP, UDP/IP
- Remote Management Protocol
- SNMP
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
- Wake on LAN (WOL), full duplex mode, Buffalo Web Access, teaming support, Apple Time Machine compatible, port trunking
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 3.5"
- 1 x Ethernet 10Gb , 2 x Ethernet 1000Base-T , 2 x USB 3.1 Gen 1
- RoHS, VCCI Class A
- Power Device
- Internal power supply
- Voltage Required
- 85 Watt
- Software Included
- NovaStor NovaBACKUP, NAS Navigator2
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85%
