TeraStation WS5020N6 series is a high-performance network attached storage with the power and convenience of Windows operating system. TeraStation WS5020N6 series features native 10GbE connectivity and achieves increased reliability by populating with hard drives built specifically for always-on NAS devices.
The WS5020N6 seamlessly melds with networks' existing Windows computers and server enabling quick straightforward deployment and massive storage capacity available in an instant. WS5020N6 is an ideal solution for consolidating multiple file servers into a single solution that enables cost reduction and lowering of the overhead on your existing servers for other workloads.
Once deployed, users will find WS5020N6 enables full Active Directory integration facilitating comprehensive access management, policies, and security. This allows networks to automate access and manage storage in the same way as they do their Windows Server. PowerShell and Microsoft Systems Center are ready-to-use, as well as a flexible choice of storage protocols (iSCSI, CIFS/SMB, NFS). Your most demanding applications and processes, such as replication, SQL, a fast-indexing search during an anti-virus scan, and more, are no problem for the WS5020N6.
- BUFFALO TeraStation WS5020N6 Series WS5420DN08W6EU - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- 17 cm x 23 cm x 21.5 cm
- 7.4 kg ()
- Processor
- 1 x Intel Atom C3338 (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 1, 5, JBOD
- Hard Drive
- 4 x 2 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2016 Workgroup
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.11 - 10.13
- 3-year warranty
- NAS server
- Host Connectivity
- 8 TB
- 17 cm
- 23 cm
- 21.5 cm
- 7.4 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 8 GB DDR4
- ECC
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 1, RAID 5, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 2 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, UDP/IP, SMB
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), Server Message Block (SMB)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 2 x USB 3.0 - Type A , 1 x Ethernet 10Gb - RJ-45 , 2 x Ethernet 1000Base-T - RJ-45
- LCD display
- Power Device
- Internal power supply
- Voltage Required
- 58.6 Watt
- Power Consumption Stand by
- 3.7 Watt
- Software Included
- NAS Navigator2, NovaBACKUP Buffalo Edition (11 licences)
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
